99 squealing noise
Google
Web AF
jlscoular
02-24-2004, 03:07 AM
my 99 grand am gt makes a squealing noise when accelerating anyone know what might be causing it
achievasc92
02-24-2004, 01:24 PM
where does the noise sound like its coming from? Under the hood, from the wheels?
Markgase2000
02-24-2004, 10:17 PM
check your serpinetine belt , if its worn or cheap it will squeek or if theres some power steering fluid leakin on it it will squeek too
Pontaic194
03-04-2004, 11:40 PM
if the belt is squeaking, for a cheap fix for a little bit, take a peice of lumber crayon (3 bucks at home depot) and run the car and rub it on the ribbed part of the belt, it will stop the noise for a little while. BUt watch your hands!!!!
bouches
02-03-2005, 08:45 AM
It is the serpentine belt. I had the same problem just two days ago. I had a leak in intake manifold (or gasket...whatever) and I guess it leaked onto the belt and when they cleaned it, it started to squeak when accelerating. They replaced it and now the squeak is gone. The belt cost $77 CDN for just the belt. They covered the labour under the warranty work for the intake.
Degtr
02-03-2005, 04:27 PM
If the belt doesn't do it, it could also be the belt tensioner is no longer applying the right amount of resistance. I had to replace that after replacing the belt itself failed to solve the problem, although I had more of a chirp than a squeak.
Google
Web AF
