over heating
Google
Web AF
ldanley
02-23-2004, 03:31 PM
My grand AM is over heating. It seems the fan is not running. I took it to a service center and they change the fan, but it is still not running. The thermostat and the Temperature sensor has been change. It starts to run hot with only a little bit of water drained from the engine from continuous over heating (just a little over the first mark on the temperature gauge). I think it could be the switch but I do not know where it is located. Even at high speeds the temperature stays a little over the first mark. The faster I go (75-80) the more it starts to over heat instead of being cooled by the wind.
jerzeygrl
02-23-2004, 11:37 PM
water pump?
ldanley
02-24-2004, 05:04 PM
Wouldn't water be leaking from the water pump if it was bad?
achievasc92
02-24-2004, 06:23 PM
drain you coolant and run a bottle of coolant flush throught the systrem. Sounds like either your coolant is old or you have a blockage somewhere.....or both
grnpontgagt
09-06-2004, 12:47 AM
Does your fan run now? When I had the fan replaced they
did not replace the relay for the fan (so it cont. not to work) put the fan in backwards- it was actually pulling hot air over my engine instead of cooling it.I don't know much about cars, but I hope that info. might help.
lefty13lefty
09-07-2004, 12:20 AM
It could very well be a cracked head or a head gasket. i have a 1994 grand am that overheated and it never leaked any coolant. the crack just allowed it to leak through the water jacket. i recommend that you pull the head and have it pressure checked, i doubt its the water pump they have a steel impeller and dont have a history for going bad, it also might be blockage, but i would highly recommend having the head pressure checked.......GOOD LUCK
richtazz
09-08-2004, 01:04 PM
either your radiator is blocked, or you have a bad t-stat. IF it was teh fans not kicking on, it would cool off as you drove. The water pump would leak or make noise if it was bad, so change the t-stat, and if it's a v-6, make sure to bleed the air out of the cooling system when you're done. If it still overheats, you have a blocked radiator.
Google
Web AF
