Oil Pressure Question
Google
Web AF
96Maro
02-21-2004, 06:36 PM
I have a 1996 Camaro 3.8 V6. The old motor went out so we put a 97 camaro 3.8 in it last month. When the car is warmed up and at idle the pressure stays a little above the 1/4 mark on the oil pressure gauge. When the car is warmed up and going down the road the ol pressure is right at the 1/2 mark. Is this normal oil pressure or is it too low? I am trying to decide if i should keep the car or not. Thanks.
89IROC&RS
02-21-2004, 10:28 PM
yeah that sounds fine. you dont want full pressure, youll burn up your oil pump, and you probly ahve a blocked oil passage. 1.4 at idle, and 1/2 at cruizing is normal.
89IROC&RS
02-21-2004, 10:29 PM
1.4 = 1/4 whoops :)
96Maro
02-21-2004, 10:46 PM
Thanks for the imput. My friend has a 96 rs with about 170,000 on it. He rides it hard all the time but his oil pressure seems to be a little higher than mine. His always stay at 1/2 even at idle. I just wanna make sure mine is ok.
89IROC&RS
02-21-2004, 10:50 PM
yeah man, your good, just remember that those guages are more like Idiot lights than autometer caliber guages, if it dropps to zero or pegs at full pressure, you got a problem, anything between, pretty much ok unless you hear something like a ticking from the engine.
Lotus49
02-22-2004, 05:51 PM
mine is always pegged.. even when i 1st start it up..after about 3000 it drops down a lottle below 60.but not much... i tried replacing the sensor... i even called the previous owner... he the pressure has awlays been pegged.. even when he replaced the engine :O
89IROC&RS
02-22-2004, 07:49 PM
um..... thats an odd one. oil pressure is usuallyhigher while the oil is cool, and pressure drops as it warms up, you might need a new guage cluster, the oil pressure guage may be out of calibration.
Google
Web AF
