97 Blazer..Truck dies for no reason
Google
Web AF
toptenblue
02-20-2004, 10:00 AM
Have a 97 S-10 Blazer. The truck just started shutting off for now reason. The air bag light will come on all the time. Sometimes the truck will start itself again. And sometime I will have to pull off and re-start it. Also It seems to have a much harder time starting. Either in the morning or if I shut it off for a few minutes and try to start it again. HELP...
xjoeharperx
02-20-2004, 11:06 AM
Sounds like you have a loss of spark. Check all the connections to the distributor, coil , and the computer.
toptenblue
02-20-2004, 11:31 AM
I'll check that out. I just did some work on the brakes. Would that have done anything?
xjoeharperx
02-20-2004, 12:30 PM
Probably not...
al smiley
02-29-2004, 06:47 PM
i have been having the same problem i had a diagnostic run on it and they said it was the crank shaft sensor. i have bought mine but i have not put it on.
cobra1
02-29-2004, 10:01 PM
after you check the ignition, cap, wires, etc., check the ignition switch. some years have had trouble with ignition switches.
when it cuts off again, and your still rolling, try wiggling the ignition switch and see if it starts running again.
toptenblue
03-01-2004, 11:45 AM
I think it may be the ignition switch. Removed and cleaned it yesterday. Also found alot of corrosion on the batt. term. I hope this fixes it.
sleslie17
03-02-2004, 02:55 PM
I have had similar problems. See my post (sleslie17) on my 97 Blazer for some ideas. I am goping to try thr Crank Pos Sensor. We may have ruled out ignition switch, but just in case - how hard was it to remove and clean?
-Shawn
Google
Web AF
