93-starts,runs,die's,wont start,then repeats
Google
Web AF
BAYOULORD514
02-18-2004, 12:22 PM
Ok, i have a 93 granda am,it's will start,run and drive down the road.It then die's,no stall or stutter,just die's.
run theu the wire harness as per checks in the repair manual,ingnition mod was bad,replaced it,coils good,map tested good,injectors tested good,replaced fuel filter,alas still die's,
as for testing the fuel pressure...theres no bloody shrader valve to hook the tester to,lol,any ideas?
BAYOULORD514
02-18-2004, 12:28 PM
oh,an althought the map sensor checks out ok,its the only code i get,34,,an it has no mass air flow sensor ,so that leaves the code to map,which i am assuming is there from the car die'n
BAYOULORD514
02-18-2004, 01:02 PM
lord,wheres my head,,,enigine is a 2.3 sohc
BAYOULORD514
02-18-2004, 05:02 PM
just rigged up the fuel pressure tester,fuel pressure at 60 psi,,about 10-13 psi high,,could that be a cuase(maybe blew out my injectors?)
Google
Web AF
