timing belt
View Full Version : timing belt timing belt raiders73 02-17-2004, 10:02 PM Pac_Man KatWoman 02-22-2004, 08:44 PM You have to turn the crank by hand and make sure the arrow marks on the crank and on the oil pump housing line up. If you have a DOHC motor, there are tick marks on the cam gears and those should line up. The cam(s) should also have a small hole in them, toward the passenger side of the motor. When those are pointing straight up you are at top dead center. Pistons 1 and 4 should be up and 2 and 3 should be down....all these conditions must be met, not just 1 or the other. If a local shop quoted you $210 to do the job, then that is awesome....shops where I am at want $500 and up. If you don't feel confident enough to do it, let a pro do it. Neons have interference motors and if you screw up the timing or don't tighten things down properly, you could be shopping for a new motor. Anaudiophile 02-23-2004, 01:28 AM My advise to you is to take it to a professional. If you'd have a 1st gen Neon I'd say do it yourself because they are very easy to do. But the 2nd gen Neons have a completely different front engine mount and bracket assembly which is not easy to extract to access the timing belt cover. Otherwise it's a very simple job to do!! Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
