Turn signal bulb replacement
Google
Web AF
tortelvis34
02-17-2004, 08:06 PM
Has anyone replaced their side marker or turn signal bulbs? How do you get to them. :banghead: I can see the back of the socket but I can't figure out how to get into it!!! :banghead:
Rick246
02-17-2004, 10:28 PM
I have replaced my turn signal bulbs, I used the manual, it has detailed instructions, if you don't have a manual, I'll copy the instructions for you. On the subject of turn signals, does anyone have trouble with the turn signals acting up, my front signal wil not work sometimes and cause the bulb out sensor to flash the signal fast. I have tried everything from replacing the bulb and the socket. I notice a lot of other Ventures driving around with one light out.
Graydevil
04-25-2004, 08:27 PM
Open your hood and around the head light assembly you will see one screw joining the two assemblys together remove the screw. take the side assembly out and change the bulb
Google
Web AF
