Newbee to this forum with 95 bonneville starting problem
minocqa
02-17-2004, 01:19 AM
hi
i'm new to this forum. i really like it there is a lot of info on it.
i have been reading for about 2 hours on it.
i have a probelm with my daugters 1995 pontiac bonneville
i changed the head gaskets this fall and had the valves ground and replaced one ofthe heads.
proir to the head gasket probelm the harmonic ballancer went out
so i replaced that. now everything is back together and the car
wont start.
it turns over and it has spark, but i'm not sure about fuel pressure
and i dont know how to check it.
it really has me baffled please help
thanks
Don
amac209
02-20-2004, 07:09 AM
get a pressure guage and twist it on to the schrader valve(has a thing like a valve cap) i don't remember what the fuel pressure should be but i think its around 50-60 psi try spraying some starting fluid in the intake and see if it fires. you could also get a cheap set of noid light to test the injector pulse. i'd say you left something unpluged or not plugged in all the way. double check all the wiring and check the fuses. e-mail me if you need more help
