ignition key cylinder removal
Google
Web AF
skutrlady
02-15-2004, 12:27 PM
I need to know how to remove the ignition key cylinder from a 97 Grand Am. I lost my keys and had 3 different "new" keys made. They all work in the doors and trunk, but won't turn in the ignition. I was told I needed a new key cylinder, but can't figure out how to get the cylinder out. Help!
Overtime
02-15-2004, 10:18 PM
In order to remove the cylinder, you have to have to remove the column cover, turn the ignition to ON (with the key) and press the release button towards the rear of the cylinder housing. To replace the cylinder is more expensive than paying a locksmith to make you a new key.
FYI, I had a new key made for mine and when I put it in the ignition, it would not turn. I had to take it back to the place I had it made and have them run a wire brush over the key to smooth it out. By reducing it slightly, the key finally turn the ignition. Also, when I had the key made, they had to verify that the key blank they used was the correct one. There are two GM key styles. One is about a half inch longer than the other. Since it has been a while, I don't remember which I had to have...
urweak
02-16-2004, 08:46 PM
i had a problem the other day where i couldnt turn the ignition to start the car, and i just took my tire iron and hammer the key into the ignition, works just fine after that.
Google
Web AF
