Starting Problems
Google
Web AF
Euroguy026
02-14-2004, 10:21 PM
Not a Huge Problem but its annoying, im proud of my chevy but somtimes i go to start it and is turns over and nothing leave it for one sec and start again and then it starts but not nicely drive for awhile and leave car and start it 15 mins later starts right up. Any Ideas? The car doesnt start the first time sometimes, any reason why? I have new plugs wires battrery everything cars engine is well maintained any reason why? Ignition Coil Starter? I dont think Fuel Pump but maybe...what u guys think
93 Chevy Lumina Euro Coupe
3.1 V6
New Plugs Wires
New Battery
New Tires
Everything else pretty much stock from what i know im only the second owner of car, 138,000 miles on it now and still runs Really Smooth n Looks even better. check it out here n vote u like it!-www.cardomain.com/id/euroguy026--
Euroguy026
02-15-2004, 10:24 AM
I Always use premium gasonline and i also just put in some fuel injector cleaner, when i mean i always i really always use premium i never used regular, i use Plus somtimes when im rich or have alot of money
pcv
02-15-2004, 10:31 AM
I think you might have a fuel system problem, possibly the fuel pump. You need to hook up a fuel pressure gauge and monitor the fuel pressure overnight. If the fuel pressure drops down significantly after sitting for a while, you may have the fuel pump leaking internally, pressure regulator may be weak or even an injector or injectors leaking down. Lets not forget a slow gas line leak.
Next time you go start your car, try cycling your ignition key to the on position 3 or 4 times, all the time listening for the fuel pump turning on and off. This will prime the fuel lines, and if the car goes vroom, (starts)you have a fuel system problem.
Good Luck.
JERKY420
02-15-2004, 10:32 AM
just wondering if you let the fuel pump prime itself when you try to start it you are supposed to turn the key forward and wait to crank it over for about 8 seconds somepeople turn the key right to the crank position and it usually starts but it really isn't the best way to start a car. And with the premium gasoline, it is always good to use premium but on the older cars it is unnecessary but if you feel it helps more power to ya.
Euroguy026
02-15-2004, 10:33 AM
Yep i always hear the pump whinning up and down after shutdown
Euroguy026
02-15-2004, 10:34 AM
My car is a 93 and i just thought using premium will keep the engine in a bit better shape
Overtime
02-16-2004, 08:43 AM
JERKY420 is right about Premium Grade gas. You might want to read this:
http://www.usatoday.com/money/autos/2003-07-30-premiumgas_x.htm
The one benefit you might recieve from using premium would be a more complete burn from the higher octane (correct me if I'm wrong).
I'd say pvc may have hit the nail on the head with his diagnosis. Did you run the test he suggested? I noticed you did verify the pump running, but did you try priming the pump a couple of times before you attempted to start it?
Euroguy026
02-16-2004, 09:16 AM
yes i only had to turn the key to the on position once let it sit there for alike a couple of seconds n turn it. So far no problems, i have had this prob b4 but i always use fuel injecter cleaner and it always goes away, maybe its the fuel pump idk, But the pump is running and i can hear it.
Jeremy-WI
02-16-2004, 09:37 AM
How often do you change your fuel filter?
Overtime
02-16-2004, 09:58 AM
Good call, might not be clogged enough to cause a big issue yet.
Euroguy026
02-16-2004, 04:46 PM
Havent Changed Fuel Filter Yet, think i should and is it an easy job i did this b4 on my hyundai it was simple as cake hope its as easy on my chevy
Euroguy026
02-16-2004, 04:47 PM
Reading the other posts maybe i should use regualr gas, maybe my knock sensor doesnt like it or somthing lol ill try i during the summer, PS: Ive always used premium ever since i bought this car and only recently has this happened it happened once to me like an isolated incedent, and then now kinda every other day o well i hope the fuel injector does it and maybe ill change the fuel filter if u guys think its a good idea-Hasnt Happened in 2 days cross fingers
JERKY420
02-17-2004, 07:17 AM
to chang the filter you have to raise the vehicled rearend crawl under right by the fuel tank (just in front of the rear tires) and you will see it right next to the tank on the front side spray them with a penetrating lube first couse they can be stubborn and you really dont want to fix fuel lines, and use a line wrench just to make it the easiest for you good luck.
Google
Web AF
