front speakersStr8in 02-14-2004, 10:18 PM Does anyone know the size of the fron door speakers on a 87 si? T.I.A cvcc_wagon 02-14-2004, 11:50 PM my bro got 6" speakers for his 89 crx (pretty nice aftermarket ones) i rmemeber tearing it apart, its pretty adaptable for anything in that size range. i have an idea tho, pull the cover off and have a look :) Str8in 02-15-2004, 12:44 PM you see thats the problem the car has no speakers or radio so i cant just take a speaker out n look. cvcc_wagon 02-16-2004, 08:05 PM look in the hole and measure it, my bro didnt have any speaker either, it was kinda funnie actually because we didnt know that when he got it, we just thought it had no deck so when we put one in and got everything hooked up (very clean i mite add, he got a honda adapter and everything and it looked beautiful, damn i do good work...) there was no sound and i was like, did u check to see if there were actually speakers? anyway, the frounts were just 6" and the holes lined up, they should be the same for you. if u are still worried go to a wreckers and pull one out and take it with you when u get the new ones. briea 02-22-2004, 02:09 PM any place you go to buy speakers should know. just tell them what car you got and if they dont know they can look it up. but i got an 86 si and the are 6" QuackerStacker 03-07-2004, 08:48 AM now i have a 86 si but it is close and mine came stock with little like 3 inch speakers but you can upgrade easly to at leat 6inch DarkstarCRX13 04-08-2004, 03:24 AM Stock front speakers are four inch but you could get bigger if you wanna make the hole bigger Condor 04-16-2004, 09:37 PM 4 inch on the front speakers. you can put in 5 1/4 using the original grills by enlarging the white plastic brackets (cut them out), then, because the tweeter part will most likely not let the original cover back on, you have to CAREFULLY snip the plastic on the back of the grill, leaving just the cloth part. This will then fit, maintaining the original look of the 4 in speakers. Be careful not to rub the window handle across the cloth when you roll down the window. Condor 04-16-2004, 09:39 PM ONLY cut the back of the speaker cover - the plastic supports where they touch the tweeter. If you cut all the plastic out it will be ruined. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
