Installing water pump '98 Blazer
Google
Web AF
Tremon123
02-14-2004, 05:09 PM
Another victim of Dex-Cool. Can anyone tell me how to change the water pump in a '98 Blazer? Is there a website with an illustration of the engine? Thanks
Jeremy-WI
02-14-2004, 06:11 PM
you might want to try www.autozone.com enter your vehicle info, click repair info, vehicle repair guides, engine and engine overhaul, then on the right side select water pump. Usually the biggest pain is getting the fan clutch to spin off the water pump shaft.
Tremon123
02-14-2004, 08:37 PM
Thank You Jeremy , That was exactly what I needed to see. Now, onto the real life task! :smile:
Jeremy-WI
02-14-2004, 10:12 PM
look at this thread to see what I use to get the fan clutch off the water pump
http://www.automotiveforums.com/vbulletin/showthread.php?t=189365
Tremon123
02-15-2004, 05:44 PM
Ah ha!!! Worked on getting the fan clutch off for a couple of hours. Then went to Murrays Auto Supply and rented the Ford Fan Clutch Wrench Set. It was off in less than a minute. Amazing. It works on Chevy even though it is made for Fords.
Google
Web AF
