At what level is my transmission full of fluid
View Full Version : At what level is my transmission full of fluid At what level is my transmission full of fluid Wayneandmel 02-14-2004, 11:27 AM F-106 Delta Dart 02-14-2004, 05:26 PM Just changed the manual fluid in my son's 92 Stealth. You are to park it on a level surface and take off the fill plug. The fluid should be at the bottom of the fill hole. When I put the fluid back in a little had run out and when it stopped I knew the level was right. By the way I replaced his manual gear oil with synthetic fluid and it made quite the difference. Hope this helps. Wayneandmel 02-15-2004, 09:00 AM Thanks. I didn't want to over fill it. Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
