Passing Thru the Firewall?skotmxpx 02-14-2004, 01:20 AM Anyone have suggestions about where to pass some wires thru the firewall? I've searched and searched can't find a good hole for 2or3 18guage wire. I tried piggybacking with the main cluster under the stering column (that isn't happening). Just wondering if anyone had any secrets they would let me in on. Thanks, 99 Blazer 4.3L, 4door, 4x4 ofcmlong 02-14-2004, 04:59 PM Probably the best thing to do is to make a new hole. Just be careful. Measure inside and out to make sure you aren't going to hit anything vital. Around the pedals would probably be good. Make sure you seal it up when you are done so no water gets in. Hurst25 02-15-2004, 01:55 AM If I'm not mistaken there is a bundel of wires that passes threw a larger gromit on the pasenger side of the firewall. I used to install and maintain equipment on squad cars and emergency vehicles, and if I remember corectly we ran an 8 gauge wire threw a large gromit there on 1st gen S10 Blazers. Hope this helps, I worked on so many different kinds of cars doing that job, its hard to keep them all straight. Jason En_Til_Za 02-16-2004, 04:32 PM fine a place where another wire ro group of wires goes thru then just feed it thru the same hole it may seem tight but fi there is a ruber groumet it will work I was able to push a 4 gauge wire thru where all ym other wires go thru you may need to remove soem trim or pull soem carpet back to find where the others wires are at it workes easiest with 2 peopel one to push the other to find it and pull it thru vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
