63 Nova rearend
Google
Web AF
oscars63
02-11-2004, 12:50 PM
Will a rearend out of a s-10 pick-up in my 63 chevy 2 post let me tuck
a set of P195 60R 15 's nicely? If not where do I start cutting with the
torch????????? I got the striker in my hand....HELP!!!!
big dwag
02-11-2004, 04:05 PM
Well i know that the rearend from a 85 s-10 will fit under my 75 nova, i don't see why you should have any problems.
acadian
07-31-2005, 02:59 PM
A rearend from an S-10 will not fit in your 62-67 nova or acadian. I have a 63 acadian and an S-10 rearend I wanted to use. You would have to move the spring locations inward to have any tire clearance unless you want to run little skinny tires, as in factory width. I found a 9" with 4:10's and a posi, that was the perfect width. No modification required, other that changing the spring saddles. Cut off the ones on the 9" and weld on the ones from your stock piece of junk rear end.
Google
Web AF
