Programming keyless remote 1995 Blazer
Google
Web AF
tdinman
02-10-2004, 01:38 PM
I just bought a keyless remote for my 1995 Blazer, can someone give me the programming directions for this? The dealership wants to charge way too much! Your help is greatly appreciated!
rlith
02-13-2004, 05:46 AM
Drop the lower driver side kick panel, you will see a red connector not connected to anything. (The black box you find is the actuall keyless entry unit) In the red connector you will see 2 pins.. Use something (such as a pair of needlenose pliers) to connect the pins together. (This must be done with the door closed) The locks will cycle and you will be in programming mode. (maintain the connection on the pins) Press and hold the unlock button on the remote till the locks cycle again. Your remote is now programmed.. Below is a pic of the connector...
http://www.pghconsulting.net/teal/keyprog.jpg
cubanlorenzo
04-04-2004, 05:51 PM
i dropped the lower driver side kick panel but i dont have a red connector on the black box. my car came with the keyless entry stock from the dealership. is there another way or andother set up that GM used???? any info will help, thanks.........
Google
Web AF
