booster problem?
Google
Web AF
rvizi
02-07-2004, 10:06 PM
I have a question that I hope I can get some help on. I bought my 2000 gtp a couple weeks ago and it has 113000 miles on it. It ran fine except when I bought it it had the trac off light on. Figured I would find out what the problem was soon but today I was on the highway and when I gave it gas the booster sputtered and made a clunking sound. Now when I speed up it hesitates when the booster goes to kick in and loses power. Regular acceleration is fine. SES light came on but went off and hasn't come on again. Has anyone ever had this problem and if so can I get some insight what this might be. I would greatly appreciate it.
Ripn12s
02-07-2004, 10:54 PM
sounds like a misfire
There should be a code set since the ses light came on. Take the car to autozone and have then scan the car and see what code the car threw
Also,
If "booster" = supercharger then try this. Take off the supercharger belt and go for a drive. Does it do the same sputter and clunk noise????
rvizi
02-07-2004, 11:10 PM
Hey thanks I am going to autozone tomorrow to check it out. I have no warranty because I bought it outright and pray that it is not the supercharger(booster is supercharger...sorry.) So hopefully it is something simple...once again thanks
Ripn12s
02-07-2004, 11:12 PM
Cool, when u get back from AZ post the results.
Try removing the supercharger belt too, see if any noises you've been hearing go away. You can drive the car w/out the supercharger belt on, it's perfeclty safe. The car will just feel alot slower.
rvizi
02-07-2004, 11:25 PM
I will take off the belt and try that too ...thanks
kilroypr
02-08-2004, 10:40 PM
If the test Ripn12s is telling you comes fine, then set aside 1500 to get a new SC. If you have patience is a bolt on and you can do it, is important to find out what TC's you will get from the computer history
Ripn12s
02-08-2004, 10:44 PM
1500 - you are on drugs tonight arent u :)
Let us know what you find out w/ the tests and scans and we can go from there.
If something is wrong with the blower then there are a few different things that could be wrong.
rvizi
02-09-2004, 05:03 PM
Well, went to autozone. They could not read codes because there must be an electrical problem with my plugin. Can this be caused from someone who owned the car before not knowing how to connect or disconnect a radio?? My car goes in tomorrow and hopefully this problem is just electrical or plugs. Another quick question...if the ses light just blinks and goes off will a code still show? Thanks for any input so far. What a headache.
Ripn12s
02-09-2004, 05:08 PM
That sucks.
I think it will still show a code. I think if the light is triggered then a code is stored.
rvizi
02-09-2004, 05:14 PM
thats what I thought but he tried three different readers and none of them worked.
Ripn12s
02-09-2004, 05:20 PM
Sucks that we couldnt solve this w/out the a shop getting involved.
Let us know what they say at the shop.
Ripn12s
02-09-2004, 05:26 PM
Did u try removing the belt??
And, u say the scanner didnt work? do u mean that it worked but didnt pick up any codes or that it didnt work at all??
rvizi
02-09-2004, 06:10 PM
Trying belt tonight. The device he used had power but couldn't get power from my car. Big ?? No idea why I have no power down there.
rvizi
02-17-2004, 04:44 PM
Hey its me again... got a couple questions for anyone who can help. I finally got a code. (I could not get a code because the ciggarette lighter fuse was blown...if that is blown you won't get power to read codes) Well anyway the code is P0128. Went to autozone and they told me it was a coolant temperature censor and possibly a temperature switch. Could it be anything else and would this problem cause my car to studder and want to stall when I give it some gas at around 45 and above?? Any help would be GREATLY appreciated. Thanks
Google
Web AF
