foggy windowsdel sol 101 02-05-2004, 03:26 PM Hello, I have a 93 del sol si a few months ago. so far it has been a good car, but i have a problem with the windows fogging up. is this normal because the car is small? what can be put on them to prevent this? i have tried fog x stuff from the rain x company, and this is a bad product. any suggestions? thanks, Plastic_Fork 02-05-2004, 04:19 PM It's normal. Mine fog up too when it rains, etc. Just make sure the air recycle button isn't on so you're getting air from the outside to equalize the air humidity and if you run the front defogger, just turn on your A/C with it. Always clears up my fog. Might be wrong, but I think this trick is in the owner's manual. If not, it was in my roommate's Integra owner's manual. Works just the same. wwest 03-02-2004, 04:23 PM we have a 2003 nissan quest, when two adults and four children get in the car the interior foggs up and it is difficult to clear up. Van has been to dealer already, they found no problems, used ac with heat, read manual with their suggestion, still didn't help. this problems only happens in the cold weather. any help or suggestions would be greatly appreciated. Anybody incounter this problem also? Given that your vehicle is of Asian/Japanese origin the climate control system is most likely of NipponDenso, Denso USA, design. With the change-over to the new less efficient non-freon refrigerant several design changes were deemed necessary. First, the A/C cooling evaporator, heat exchanger, was made a lot more dense and complex. The more chilled surface area for the air to flow over, the higher will be the efficiency of the heat transfer. The second issue is more directly pertinent to your problem. The slower the air flows over the evaporator's cooling surfaces the more it will be cooled and the more it is cooled raises the likihood that it will be simultaneously DEHUMIDIFIED. Another benefit of the lowering of the incoming airflow rate is better MPG, something I'm sure the automotive manufaturers haven't over-looked. Almost all modern day passenger vehicles are very well sealed against atmospheric outflow for these reasons. The way NipponDenso has chosed to keep the evaporator airflow as low as possible is by restricting the cabin atmosphere OUTFLOW. The result of that is that during the cooler months it will be really easy for the passenger cabin to become extremely humid, so humid that the windows and windshield interior surfaces, cooled continously by exposure to COLD outside atmosphere, begin to fog over. My suggestions... If it is possible to completely disable the A/C during the winter months then do so. My 01 RX300 has C-best options which allowed the dealer to "unlink" the automatic operation of the A/C in both "normal" and defrost/defog/demist modes. ON a previous 92 LS400 I fooled the system into thinking the OAT was below 32F by adding a resistor in series with the OAT sensor. I have also, on occassion, simply disconnected the A/C compressor clutch electrical circuit. My 01 Porsche has a switch added within the glove box that does that. If you park the vehicle inside it will help to leave a window or windows open so the cabin can more completely dry out. During A/C operation the ~10,000 square inches (92 LS) of evaporator surface area will become saturated, clogged, with mositure and while much of that will drain away via the provided drain a lot will remain and then evaporate into the A/C plenum and thus into the passenger cabin at the first start of the system blower. My most common occurance of intermittent and spontaneous windshield fogging was about 5 miles into my morning trip to the office during the cooler months. That instance was cured, mostly, by leaving the windows slightly open during the night in the garage. Another instance is that the A/C compressor will oftentimes shut down spontaneously, without any indication to you, if the OAT declines to near or below freezing. A few minutes after that happens the condensed moisture remaining on the evaporator will begin to evaporate into the airflow entering the passenger cabin. Be VERY CAREFULL, this can be a very HAZARDOUS situation. If you are traveling in a colder climate and begin to see wisps of condensation on the interior surface of the windshield DO NOT ACTIVATE the defrost/demist/defog function before you turn the system heat all the way to MAX! Those wisps of condensation might be indicative of the A/C compressor having previously shut down due to low OAT and now if you activate the defrost/defog/demist function the COLD windshield will become suddenly opaque from condensation due to the moisture bomb building up with the A/C plenum. The best procedure to use if you sense that the humidity is to high within the passenger cabin is to lower the rear windows slightly and quickly purge the humid atmosphere from the cabin. While I remain a strong advocate of the use of A/C to dehumdify the incoming cabin airflow and thereby help to remove windshield condensation and prevent it's formation, I don't understand why, other than the slight discomfort one might feel, the defrost/defog/demist airflow isn't also HEATED. Wwith Outside Air Temperatures, OAT's, below about 55F it is impossible to predict whether or not the the A/C can be efficient enough to be of any help. The A/C's dehumidifcation efficiency is a function of the relative humdity of the incoming airflow. The lower the temperature of the incoming airflow the lower is the probability of efficient dehumdification by the A/C until at about 35F it is practically non-existent. 94SolGrl 03-02-2004, 05:21 PM Wow that's a lotta info... good info, too, but it's one of the sol curses to have fogged windows.. fogged windows, leaky seals, leaky trunks.... that's whatcha get when you get a sol.. I run with the windows down as much as possible, but other than that, running with the AC on 24/7 is basically the best bang for your buck. Sucks, yes, but it's a small car, and the interior design is awkward for air circulation... you'll notice it's usually the two corner (triangle) windows that get fogged.. that's because they're where the air doesn't circulate hardly at all. Just a design flaw. If it gets really bad, open your back window. That's what it's really there for ;) Plastic_Fork 03-02-2004, 08:05 PM it's one of the sol curses to have fogged windows.. fogged windows, leaky seals, leaky trunks.... that's whatcha get when you get a sol.. ... you'll notice it's usually the two corner (triangle) windows that get fogged.. that's because they're where the air doesn't circulate hardly at all. Just a design flaw. If it gets really bad, open your back window. That's what it's really there for ;) What she said. I normally just point my side vents at the corner windows, set the temp control to medium, lower my rear window a bit, and run it with the A/C on for a few minutes. Usually clears it up pretty quick. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
