xenon lamps in prius ????
plnf
02-05-2004, 06:43 AM
Hi guys another time, your friend from Poland, does the new prius got the xenon lamps (option?) ?
THX
jdub96
02-05-2004, 01:24 PM
Depending on the option package that you choose they come with HID headlamps.
lillucas
02-16-2004, 09:32 PM
yes, it gets xenon lamps as an option inside packages
i think package 7 comes with that
jdub96
02-17-2004, 03:34 PM
Xenon and HID are two completly different types of lights.
Xenon head-lights are those new bright blue lights we see on the road. Heating of a filament results in a small part of visible light (classic light-bulbs). Heating of a gas results in a narrow range of visible light. Make a spark in the xenon gas and you have a xenon light.
HID (High Intensity Discharge) can be explained here:
http://www.hidkits.com/faqs.htm
lillucas
02-17-2004, 09:40 PM
looks like the Prius has both then
jdub96
02-18-2004, 11:58 AM
I can't find anything about Xenon Headlights, but on the toyota website is talks about the HID headlights in option package #s 7 & 9.
Prius Options (http://www.toyota.com/vehicles/2004/prius/options.html)
lillucas
02-18-2004, 03:40 PM
i think they really are the same
jdub96
02-19-2004, 10:18 AM
I am not trying to argue, but trust me they aren't the same.
The lights that are on the new BMWs, Audis and such are HID.
The lights that people put on there riced out Civics and such are Xenon.
The technology it totally different and so are the light bulbs themselves.
This is a HID light:
http://www.clubsilicon.com/images/bulbs/HID/auto/d2s.jpg
And this is a Xenon light:
http://www.vehicle-wiring-products.co.uk/VWPweb2000/lights-3/photo/XENON.jpg
lillucas
02-19-2004, 04:13 PM
i believe the one's fitted onto civics and such are just bright whites that you can get for like 20 dollars
if audi uses HID, then xenon and HID are the same because i have 4 Audis and its called xenon on there
lillucas
02-19-2004, 04:15 PM
i dont really know, do you have a site that compares the difference?
filbertman
02-19-2004, 04:36 PM
jdub is correct.
Halogen = standard car headlight
Halogen/Xenon = bright white/cool blue/HID-looking headlights on hondas (like mine) for $20
HID = fancy BMWs, Audi's, Lexii, Acuras...
When HID technology came to cars, that is the same time that halogen/xenon technology came to cars. and since xenon is designed for HID-look (higher temp/kelvin light) there is a lot of confusion.
HID does NOT equal XENON. A lot of people think they are the same, but it is b/c the term xenon has been using incorrectly for years.
read:
http://www.coolbulbs.com/faq.asp
excerpt talking about cool white/xenon halogen lights:
Our Nokya Arctic White bulbs produce about 5000°K and our Arctic Purple bulbs are about 7000°K the difference is huge.
This increase was achieved two ways, first these bulbs use a more tightly wound spiral filament made of finer wire in a precise mixture of halogen and xenon gasses that is under much higher pressure than a normal halogen bulb. The presence of xenon gas under high pressure provides an increased rate of halogen regeneration resulting in a very intense light. Depending on the design, a 55-watt version of this type of bulb can produce the equivalent output to an 85-watt or higher standard halogen bulb but without the amperage draw and heat of the standard 85 watt bulb. These new high output bulbs are becoming increasingly popular because they offer amazing output at relatively low amperage draws and heat generation.
The other important technology at work here is the tinted glass. A "High Intensity White" coating. This coating has a pale bluish tint to the glass to filter out the yellow spectrum light producing a light that simulates the ultra white color temperature of H.I.D. lamps
filbertman
02-19-2004, 04:39 PM
also... it's quite possible that the PRIUS does have xenon lights as well... these would be the standard halogen lights used on high beams. usually HID is not used in high beam b/c of the "warm-up" time associated with HID, making instant-on and quick flashing difficult (and not good for the long term life of the HID). So it's quite possible that the prius uses HID for main headlights and halogen/xenon for high beams. Also, HIDs run cooler and use less electricity than halogen/xenons... so HIDs would make more sense for the Prius.
jdub96
02-20-2004, 10:25 AM
Thank you for bringing a 3rd party into this.
That is quite possible, and if that's the case I stand somewhat corrected.
Depending on what option you choose you could have HIDs or not as I stated above and quite possibly the standard option is Xenon, the only Prius' I have seen had the HIDs.
lillucas
02-23-2004, 03:43 PM
mmm.. i hear they are self-leveling HID that turn on and off automatically :)
filbertman
02-24-2004, 07:56 AM
i hate automatic lights. self-leveling is cool. But in my STi, I can pivot them myself from inside the car!
lillucas
02-24-2004, 04:40 PM
that's mean! is that your car that's blinding me whenever i go on big bend fil?
corey415
05-27-2004, 03:56 AM
okie let me clear things up here.
HID refers to lighting technology that relies on an electrical charge to ignite gas contained in a sealed bulb. Often times, the gas used is xenon gas. However, depending on the specific type of HID application (i.e mercury vapor, metal hallide, high pressure sodium) different gases are used as a medium. For example, metal hallide hid primarily contains argon gas.
In automotive HID, the gas contained within the hid bulb is xenon gas. Henceforth, you have manufacturers saying the car has HID headlights or xenon headlights.
It is important, however to not confuse HID with halogen bulbs that have xenon gas in them. As stated by others in this thread, companies put the xenon gas into the regular halogen bulbs for marketing purposes. The xenon gas doesnt even affect the output of the halogen bulb, as the halogen filament isnt hot enough to ignite the xenon gas.
The prius with HID has HID low beams and regular halogen highbeams. Simple as that. Car companies would never use xenon halogen bulbs, since they generally produce output worse than stock setups.
KroniK187
09-02-2004, 10:43 AM
I know that this is an old topic but your wrong corey. The prius that comes with hid has an option only has 1 bulb for the high/low beam, meaning that it use the same hid bulb to light up the highs as well. Bi-Xenon
