3.1v6 fuel injectors chattering
Google
Web AF
propipe
02-04-2004, 11:27 PM
I have a 1990 lumina 3.1 with 64000 miles and the fuel injection system chatters at idle and sometimes at slow speeds is there a fix for this problem or must i replace the injectors
brooster
02-04-2004, 11:38 PM
When the injectors don't click is when to get excited. Some are just more noisy than others and temperature has some effect. If you're not experiencing any driveability problems and this annoys you, perhaps turn the radio up a little.
propipe
02-04-2004, 11:43 PM
thanks for your reply ...so what your telling me is there ok !!!!! man they can get noisy at times it almost sounds like a rod rapping ....can you tell me this will fuel injector cleaner help or maybe some spray carb cleaner in the intake ???
brooster
02-05-2004, 06:55 PM
If it sounds loud enough to be mistaken for a rod knock, you might want to have someone else (professional) listen to it.
For example many of the late model 3.1 and 3.4 have problems with the intake gasket leaking water. Sometimes to the outside, sometimes to the inside. If you get antifreeze into the oil, it can wipe the bearings.
It is difficult to access the injectors on this engine, but if you can get to them, you can listen to them with a screwdriver, hose, or a mechanics stethescope.
There are products (injector cleaner/conditioner) that claim to help quiet noisy injectors, but I have no personal experience or knowledge of how well they work. Spraying carb cleaner into the intake will not help what you're describing.
Google
Web AF
