2000 Silverado alarm problems
Google
Web AF
nitro56
02-04-2004, 10:20 PM
Every time I use my remote to lock my doors or set the alarm, within minutes, or sometimes even seconds, the alarm will start sounding. I have to manually lock my doors to keep this from happening. I also have to use my dome light override button, because the dome light will turn on by itself while Im driving. Along with that, at the same time the doors will attempt to lock themselves. Where do I begin trouble shooting or is there A way to just reset the system?
ponchonutty
02-05-2004, 07:57 AM
I'd first check the door switches. If the lights are comming on when you drive, it's gotta be that or the wires that hook to them are shorting out.
nitro56
02-05-2004, 01:26 PM
It looks like we found the problem. I just needed to reprogram the alarm. Seems to work fine now.
ponchonutty
02-06-2004, 07:45 AM
Glad you got it fixed. Not sure what you had to do though?
nitro56
02-06-2004, 11:25 AM
Thought we had it fixed but it's doing it again so I'm open for suggestions again.
ponchonutty
02-06-2004, 08:41 PM
Did you do what I said before?
nitro56
02-07-2004, 01:20 AM
I'll try what you said. Thanks!
slacker_53
02-07-2004, 10:09 PM
I have a 2000 Silverado that does the same thing....sometimes. Once in a while it will work fine, the next time you lock or unlock the doors, the alarm goes off.
It has an aftermarket keyless system that I installed myself. I have installed a bunch of these on the basically same truck, with no problem.
I don't know what is up with THIS truck!
-slacker
ponchonutty
02-08-2004, 02:18 PM
-slacker
Did you tap into the disarm wire? It's the light green wire in the purple plug of the BCM. That's if you have a 1/2 ton truck. Even if your truck didn't come with keyless, it still can have an alarm. Also, some aftermarket keyless systems have it where if you hold the lock button down, it will set off the panic alarm.
Google
Web AF
