brakes abs traction control warning help
grandvett1
02-04-2004, 07:57 PM
Jumped 2000 turbo beetle and when restarted got all three warning lamps. Fuse was blown 5amp replaced still have warning lamps???
how do i get it to reset? The abs and traction control are still offline
??? Do i need to undo the power and wait for it to reset and rehook up to batterie.?? Help
boschmann
02-06-2004, 04:41 PM
Ther are other fuses for the system. I'm not 100% sure of these numbers & locations for your model, but they should be close. I think you found fuse #9, 5 A. There is also fuse #13, 10A and under the hood there are two 30A fuses (#178 & #179) at the fuse bracket by the battery.
