Oxy Sensor/CheckEngineLight/Major gas Problem
Google
Web AF
Popsmear
02-04-2004, 02:41 PM
I do not have autozone codes handy, the machine is down at the shop for a week or two, but this problem is driving me crazy and costing me a nice amount of money.
98 Contour Sport
99,927 Miles
My check engine light is ON.
I assume it is the Oxy Sensor, though, thats just an assumption.
My gas mileage has gone WAY downhill. I used to use half a tank a week.
Now it is half a tank every 2 days, if im lucky.
I also used to use 89octane, but now with prices so high and my need to refuel so often I use 87.
I was thinking about taking it into the shop, since it probably needs more work (tune up, so on and so forth).
Any ideas?
Popsmear
02-04-2004, 02:45 PM
I will actually drive out to a different autozone tonight, and get the codes.
beyondloadedSE
02-05-2004, 12:53 PM
sounds like the symptons of a rich 02 sensor to me. Btw, 87 octane will work perfectly fine in your car.
Popsmear
02-05-2004, 01:46 PM
Yeah, I got the code
P0420 - The PCM has detected that the catalyst system efficency for bank 1 is below threshold for the current engine operating conditions. (Bank 1 indenifies the location of cylinder #1, while bank 2 indentifies the cylinders on the opposite bank)
So I bought the OS sensor for before the catilytic converter.
Will be putting it in shortly, and hopefully that will fix my problem.
Thanks for your help
nav6412
03-15-2004, 10:16 PM
:banghead: did the os sensor work I have a 95 with the same gas milage and hard starting frist thing in the morning
phreaq
10-03-2006, 02:04 AM
The forum is more helpfull when you write back, letting everyone know if it fixed the problem.
beyondloadedSE
10-03-2006, 10:40 AM
holy old thread batman!
btw, if you want a helpful forum, contour.org is the only contour forum, period. This one pretty much sucks. :disappoin
pre98zetec
10-03-2006, 10:44 AM
you should fix the link in your sig, it goes to the old forums.
beyondloadedSE
10-03-2006, 12:21 PM
done! :wink:
Google
Web AF
