97 Blazer ???keppler 02-04-2004, 07:29 AM I was under my Blazer over the weekend and noticed that the nuts were gone from the top of the stabilizer bar...both ends! I need to know if I should just replace the nuts or would it be better to replace all the bushings and spacers and if I can buy a set of the bushings? Would they be a dealer item or can I find them at Auto Zone? I purchased this truck about a month or so back and this was the first time I have been under it so I have no idea how long the nuts have been off. Now for the really dumb qustions. Where in the devil is the fluid resivior for the rear window washer fluid? I've looked everywhere I can think of but can't find it. :screwy: sleslie17 02-04-2004, 08:48 AM It must be common for those nuts to work loose - mine was making noises when I found it. I replaced them with bolts and washers I have in the nut jar - fine so far. I did not know there was a reservoir for rear H20; or never thought of it? -Shawn bruzer80 02-04-2004, 10:28 PM There is no rear washer reservoir. The hose for the rear connects higher on the main reservoir than the hose for the fronts. So if your fluid is low (less than 1/3 full) the rear will not spray, but the fronts still will. Top 'er off and check the rear spray again. keppler 02-05-2004, 08:29 PM Thanks for the info. Guess thats why I couldnt find it....duhhhh vinnie97 02-07-2004, 08:24 PM is rear spray an option? Cause I've haven't seen anything for it on my 97. bruzer80 02-08-2004, 02:50 AM If you have a rear wiper, you should have rear spray. On the rear wiper control, if you press and hold the "ON" button, the rear wiper will spray. I believe this is the only option for rear wipers on the 97 models (other than no wiper). vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
