View Full Version : test results on a wierd ign problem
pegasus757
02-03-2004, 04:45 PM
car starts runs fine untill engine gets warm ,(not hot,.. indicator shows about mid way, and fan does not come on ,i can hold the rad hose.). When it dies the front coil works, spark at 1 and 4,the back side has no spark. the coil has 3 wires.. center is pwr... fwd wire is for fwd coil and aft wire is for the aft coil. when it died out i swaped the fore and aft wires ...now the aft coil has spark and the fwd does not. Checked continuity from pins at coil to pcm ...checks good,Ok so I belive pcm is not giving the signal (ground) needed to energize and collapes coil , so I changed the pcm ...still the same results. has any one had this problem or could some one point me in a logical direction. THNX in advance PS... remember, test dont guess.........HERE ARE THE RESULTS.....the crankshaft sensor would get warm and the pickup inside caused an interrmittant open.. found the problem. Went to the zone ,sensor was 28.00 also needed a special pig tail (they didnt have) ,went to dodge they wanted 88.00 for sensor,so i just bought the pig tail...car runs fine now
Related Links
Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free.
