door opening mechanismdust333333er22 02-02-2004, 10:53 PM The front driver door will not open from the inside on my 97 burb. The outside handle works fine. I opened the panel on the bottom of the door and the rod attaching the interior handle is still conntected the opening latch. Any suggestions? ssprint 02-09-2004, 06:14 PM The front driver door will not open from the inside on my 97 burb. The outside handle works fine. I opened the panel on the bottom of the door and the rod attaching the interior handle is still conntected the opening latch. Any suggestions? Do you still need help? I just replaced mine. Mike Skinner dust333333er22 02-09-2004, 10:40 PM Thanks, but I got the panel removed and discovered the interior metal handle was twisted/broken. I removed and replaced it. The unit Cost $25 from the dealer, not as bad as I thought. Thanks for the response The front driver door will not open from the inside on my 97 burb. The outside handle works fine. I opened the panel on the bottom of the door and the rod attaching the interior handle is still conntected the opening latch. Any suggestions? Guilow 02-11-2004, 12:19 AM Thanks, but I got the panel removed and discovered the interior metal handle was twisted/broken. I removed and replaced it. The unit Cost $25 from the dealer, not as bad as I thought. Thanks for the response Crap. I had the same thing happen but was in a major hurry and had the dealer replace mine. $144 freakin' bucks. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
