EGR Valve or Idle Control Valve
mark5
02-02-2004, 12:16 PM
I have a 2001 Odyssey and have had the following problems. First, when we were driving down the road I could feel the engine wanting to allow the vehicle to surge. So, while we were coasting I put the trans in neutral and the tach would go from 1,000 to 2,000 RPM's and back down to 1,000. It would just repeat this cycle. Also, it was a little dificult to start. Got a check engine light and brought it in. They said it was the idle control valve. After I got the vehicle back, the tach fluctuating problem was fixed but the hard starting was not. When we start the car it can take 10 seconds of cranking until the engine turns over. Finally got a check engine light and they did the EGR service bulletin for us.
QUESTION is, could the EGR problem fix the tach fluctuating problem? I had to pay for the idle control valve ($280) and would like to go back and bitch for my money!!!
mwkirchner
02-29-2004, 09:31 AM
You didn't mention how many miles you had on the vehicle when you had this done. The IAC is covered under your original warranty and the EGR update is covered for 80,000 miles or 8 years. The EGR update would NOT have fixed your idle issue. We have run across a lot of the IAC issues in work.
Here is a exerpt from the bulletin pertaining to the EGR issue:
WARRANTY EXTENSION INFORMATION
American Honda is extending the warranty on EGR system problems in the affected vehicles to 8 years or 80,000 miles, whichever comes first.
drjag
04-03-2004, 02:20 PM
I also have a 2001 Odyssey and while in park the idle fluctuates between 900 and 1200 rpm. This has just started, but doesn't happen all the time - at least not yet. Could be Idle Control Valve? I'm assuming this was not under warranty with you Honda. I have 53000 miles on my van. Is this ICV a part that can be replaced at home? drjag
acguy
08-12-2004, 08:10 PM
In August 2004 I took my 03 odyssey to local Honda delear for a problem with my transmission hunting back and forth between 4th and 5th gear around 35 or 40 mph.
After the tech rode with me and with diagnostic tool hooked up, he determined the EGR valve was sending a faulty signal to a computer thus causing the shifting symptom. They billed me $211.00 to replace the EGR valve which I payed without question since the van has 40000 miles on it and is no longer under warranty.
Then I found this site and saw that emissions equipment is covered for 8 years or 80000 miles.
I called back to the Honda dealership and asked if my van was covered.
After a great deal of research, he informed me that warranty coverage is determined from the vin number. He said mine was not.
He did say that if I was in California, it would be covered! Why do California Honda customers get a better warranty?
mwkirchner
08-12-2004, 10:16 PM
Your tech was correct on his diagnosis and also in informing you that it was not covered under warranty.
Here is a list of what parts are covered in what states and for what length of time.
2003 Odyssey California Emissions Warranty Parts List for Vehicles registered and operated in California/Massachusetts/Vermont
This list details the components covered by your California Emissions Warranties and the warranty duration in years and miles, whichever comes first. For information on your vehicle’s warranties, refer to the 2003 Warranties booklet in your glove box.
Systems Covered Coverage = yrs/x 1000 mi
Crankcase Control System
Positive Crankcase Ventilation (PCV) Valve 3/50
Engine Oil Fill Cap 3/50
Evaporative and Refueling Emissions Control System
Fuel Tank (including Fuel Tank Vapor/Liquid Separtion Valve) 7/70
Fuel Tank Vapor Control Valve 3/50
Fuel Tank Pressure Sensor 3/50
Fuel Tank Vapor Recirculation Tube 3/50
Fuel Filter*1 3/50
Fuel Fill Pipe 3/50
Fuel Fill Cap 3/50
Evaporative Emission Lines and/or Hoses 3/50
Evaporative Emission Canister 3/50
Evaporative Emission Valves 3/50
Exhaust Gas Recirculation (EGR) System
Exhaust Gas Recirculation (EGR) Valve (including EGR Valve Position Sensor) 3/50
Exhaust System
Exhaust Manifold 3/50
Exhaust Pipe (engine to catalytic converter or between converters) 7/70
Catalytic Converters 8/80
Ignition System
Ignition Coils 3/50
Crankshaft Position Sensor 7/70
Camshaft Position Sensor 3/50
Spark Plugs 3/50
Fuel Injection System
Injectors 3/50
Fuel Rail 3/50
Fuel Lines and/or Hoses 3/50
Knock Sensors 3/50
Oxygen Sensors 3/50
Engine Control Module/Powertrain Control Module (including Barometric Pressure Sensor and Software Updates) 8/80
MAP Sensor 3/50
Engine Coolant Temperature Sensor 3/50
Intake Air Temperature Sensor 3/50
Data Link Connector (DLC) 7/70
Thermostat 3/50
Fuel Pressure Regulator 3/50
OBD System
Malfunction Indicator Lamp (MIL) 3/50
Transmission Control System
Clutch Pressure Control Solenoid Valves 3/50
Shift Control Solenoid Valves 3/50
Mainshaft Speed Sensor 3/50
Countershaft Speed Sensor 3/50
Transmission Range Switch 3/50
Intake Air System
Throttle Body (including Throttle Position Sensor) 3/50
Intake Manifold Assembly 3/50
Air Cleaner Housing 3/50
Air Cleaner Housing Cover 3/50
Air Cleaner Element*2 3/50
Intake Air Duct Assembly 3/50
Idle Air Control Valve (IACV) 3/50
VTEC System
Variable Valve Timing & Valve Lift Electronic Control Solenoid Valve Assembly 3/50
Variable Valve Timing & Valve Lift Electronic Control Oil Pressure Switch 3/50
Miscellaneous Parts that are used in conjunction with the items in this list are covered. Some examples are clamps, brackets, piping, nuts, bolts, fasteners, switches, sensors, solenoids, wires, harnesses, connectors, seals, and gaskets. 3/50
*1 Fuel filter replacement and fuel tank flushing are covered when contamination results from a defect in material or workmanship. Fuel injection system cleaning is covered.
*2 Covered up to the first required replacement only; see the maintenance schedule in the Owner’s Manual. Systems Covered Coverage yrs/x 1000 mi
2003 Odyssey Federal Emissions Warranty Parts List for Vehicles registered and operated in all states other than California/Massachusetts/Vermont
This list details the components covered by your Federal Emissions Warranties and the warranty duration in years and miles, whichever comes first. For information on your vehicle’s warranties, refer to the 2003 Warranties booklet in your glove box.
Positive Crankcase Ventilation (PCV) Valve 3/36
Engine Oil Fill Cap 3/36
Fuel Tank (including Fuel Tank Vapor/Liquid Separtion Valve) 3/36
Fuel Tank Vapor Control Valve 3/36
Fuel Tank Pressure Sensor 3/36
Fuel Tank Vapor Recirculation Tube 3/36
Fuel Filter*1 3/36
Fuel Fill Pipe 3/36
Fuel Fill Cap 3/36
Evaporative Emission Lines and/or Hoses 3/36
Evaporative Emission Canister 3/36
Evaporative Emission Valves 3/36
Exhaust Gas Recirculation (EGR) Valve (including EGR Valve Position Sensor) 3/36 <------------ This is what pertained to your vehicle
Exhaust System
Exhaust Manifold 3/36
Exhaust Pipe (engine to catalytic converter or between converters) 3/36
Ignition System
Ignition Coils 3/36
Crankshaft Position Sensor 3/36
Camshaft Position Sensor 3/36
Spark Plugs 3/36
Injectors 3/36
Fuel Rail 3/36
Fuel Lines and/or Hoses 3/36
Knock Sensors 3/36
Oxygen Sensors 3/36
MAP Sensor 3/36
Engine Coolant Temperature Sensor 3/36
Intake Air Temperature Sensor 3/36
Data Link Connector (DLC) 3/36
Thermostat 3/36
Fuel Pressure Regulator 3/36
OBD System
Malfunction Indicator Lamp (MIL) 3/36
Clutch Pressure Control Solenoid Valves 3/36
Shift Control Solenoid Valves 3/36
Mainshaft Speed Sensor 3/36
Countershaft Speed Sensor 3/36
Transmission Range Switch 3/36
Intake Air System
Throttle Body (including Throttle Position Sensor) 3/36
Intake Manifold Assembly 3/36
Air Cleaner Housing 3/36
Air Cleaner Housing Cover 3/36
Air Cleaner Element*2 3/36
Intake Air Duct Assembly 3/36
Idle Air Control Valve (IACV) 3/36
VTEC System
Variable Valve Timing & Valve Lift Electronic Control Solenoid Valve Assembly 3/36
Variable Valve Timing & Valve Lift Electronic Control Oil Pressure Switch 3/36
Miscellaneous Parts that are used in conjunction with the items in this list are covered. Some examples are clamps, brackets, piping, nuts, bolts, fasteners, switches, sensors, solenoids, wires, harnesses, connectors, seals, and gaskets. 3/36
Fuel Filter*1 3/50
Fuel Fill Pipe 3/50
Fuel Fill Cap 3/50
Exhaust System
Ignition System
Ignition Coils 3/50
Spark Plugs 3/50
Injectors 3/50
Fuel Rail 3/50
Knock Sensors 3/50
Oxygen Sensors 3/50
MAP Sensor 3/50
Thermostat 3/50
OBD System
Intake Air System
VTEC System
Fuel Filter*1 3/36
Fuel Fill Pipe 3/36
Fuel Fill Cap 3/36
Exhaust System
Ignition System
Ignition Coils 3/36
Spark Plugs 3/36
Injectors 3/36
Fuel Rail 3/36
Knock Sensors 3/36
Oxygen Sensors 3/36
MAP Sensor 3/36
Thermostat 3/36
OBD System
Intake Air System
VTEC System
defreib
12-29-2004, 06:41 PM
If Honda has issued the following extended warranty, why would my 2001 Odyssey not be covered? American Honda is extending the warranty on EGR system problems in the affected vehicles to 8 years or 80,000 miles, whichever comes first.
mwkirchner
12-29-2004, 09:33 PM
I sent you an email that should answer your question. If you have any other questions, you can email me direct like you did.
turbcivic
01-02-2005, 02:29 PM
Okay let's start from the first person.
It was a repeat vist. If the part did not fix the problem the first time, the tech should be back flagged and the money for the parts and labor refunded. EVery honda tech knows about the egr problems and with odditys, that is usally one of the first things checked. I don't know if the check engine light was on but if it was and a P1129 was thrown, then there is a S/B that deals with this.
Yes, an IAC can be replaced at home. Or at least for me it is that easy.
Third person, last time i checked i thought all 2003 odditys were under this bulletion, i would have to pull it up.
