can someone help me with my hondaSkigin92 02-02-2004, 02:32 AM Every time i start my car it shuts back off i keep trying and after a while it will start but it is taking longer each time.Can any help :banghead: 89Turbo944 02-02-2004, 02:53 AM Ok, well we will have to start off by knowing what it is that you drive. As well as engine in the car, auto or standard? Mods? Skigin92 02-02-2004, 04:12 AM 1989 Honda Civic DX 1.6l mechy1barry 02-02-2004, 03:30 PM engine control relay is faulty.(not sure on overseas models where it is,sorry). NvSDuB 12-06-2004, 07:35 AM you can start with a with the basics ..., check your main relay . then ingnition compents ( mainly the ignition coil ) then move on to your fuel pressure. .. if the problem is still undetected.. try a compression test.. does the car start better when it is already warm?...or is it only happening when it is cold?... pull out a spark plug .. what colour is it? does your car have a rough idle when it does start? 95RSV 01-07-2005, 11:26 AM Do you actually think he still has the car after 10 months. shawnwilliams 04-14-2005, 01:16 AM problems like that with that old of a car unless you going to totally redo to it, just get a newer car. shawn_carter69 05-18-2005, 05:00 PM problems like that with that old of a car unless you going to totally redo to it, just get a newer car. yeah cause your 93 is so much newere than the 89. Hondas never die fucky! they will live forever!!! shawn_carter69 05-18-2005, 05:01 PM P.S. i am not pissing on ford i used to own a Focus but it got written off vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
