1999 Passat Windshield Washer low light wont go off.
Google
Web AF
Mklwhite
02-01-2004, 02:42 PM
Hi. A first time poster here...
I just bought a 99 Passat GLX and am having issues with the winshield washer fluid level light being on all the time. I filled up the tank and it still is on. Am I missing something here?
Thanks in advance.
jmac13
02-13-2006, 10:53 AM
Thanks in advance.
I have a 99 passat with the same issue. Any suggestions?
Will12
02-14-2006, 01:57 PM
I think that there should be a low level float that might got stuck or shorted out perhaps taking it out and cleaning it might help.
veedubmechanic
02-14-2006, 06:40 PM
there is a low level sensor in the tank. In order to reach it you need to remove the driver side front fender liner. Its a circle sensor that simply pushes into the washer fluid resivour. Check to see if its plugged in first, it its plugged in properly than the sensor is bad.
Google
Web AF
