Unable to Start in Cold Weather
Google
Web AF
architect
01-31-2004, 12:50 PM
I have a 2000 Venture. It won't start w/ temps below 20 degrees. I just put a new battery in it. It's like the fuel line is frozen or something. I've had the dealership look at it 4 times already. By the time they get it in their garage, it will start. I keep a full tank w/ heat in it. It's dead in the street right now.
rodeo02
01-31-2004, 01:05 PM
What are the symptoms? When you turn the key, does the engine turn over/crank, but not start? (I would not suspect a battery, starter or charging system issue in that case) or does the engine turn over & not fire up? That case is likely a fuel system related issue- like you say, frozen line, bad idle air control system, fuel pump, etc..
G/luck
Joel
architect
01-31-2004, 02:08 PM
G/luck
Joel
The engine turns over but won't fire.
GMMerlin
01-31-2004, 02:53 PM
First order of business is to determine what is missing..fuel or spark..this will lead you in the correct direction.
You can check spark by removing 1 plug wire from the plug and place the loose end near engine metal..spin the engine over..does spark jump out of the boot?
bobof15c
06-15-2005, 07:29 PM
Sounds like 4-5 others had a similar issue. Might try the fuel pump plug as noted in other 'trouble starting fuel' posts such as this:
"mmorales--Be sure to check the plug underneath the driver's side sliding door. Look under the van and you should see a couple of plugs going into the body. One is smaller than the other. The smaller one is for the ABS system and the bigger one is for the fuel pump. I had this problem and all I had to do was unplug the fuel pump clean out the connectors and plug it back in. The van started with no problems. I have had problems since then though. The van starts and runs but it hesitates and has trouble idling." Its worth a shot!
Google
Web AF
