Climate Control Panel starting to die??
flicker
01-23-2004, 09:12 AM
Hi all! I have a '92 LeSabre and noticed over the past few months that at times, I cannot change the settings on the climate control. I do not have a digital climate control, but the old "Radio button" style. If I start the car and the heat light is lit, I cannot change options. I cannot change to defrost, A/C or even off. After the engine runs for about 5 minutes, the panel starts working again. Sometime all the lights go out and I cannot select anything and air blows through the vents. There is no set pattern to whether it will work or not. This happens in hot and cold weather. If it's off when I start the car, I start driving and just keep pressing the button I want and EVENTUALLY it will light up and turn on. Any thoughts?
