99 Accord Dashboard digital clock
1999AccordLX
01-22-2004, 01:34 PM
Just bought a 99 Accord LX and I notice that the factory digital clock at the top-denter of the dash is not backlit. The only way to see what time it is at night is to turn on one of the map lights - far from convenient.
Questions are:
Is this the normal/designed behavior of the clock?
If not, how can I fix the darned thing?
Thanks.
[email protected]
Questions are:
Thanks.
[email protected]
CrAzYbEaNeR
01-22-2004, 03:26 PM
That is not a normal operation for your clock. The bulb must have burned out. There is a bulb behind the clock when you extract it from your dash. Go to your local radioshack and see if they carry that bulb.
avpart3
01-23-2004, 10:02 AM
this is a typical problem for 6th Generation accords. does anyone know where the screws are that have to be removed to get to the clock , cuz I got the same problem and it Irritates me every time I'm in the car and somebody asks me what time it is
blacknight
01-23-2004, 02:27 PM
Actually, there are no screws. Use a flat head screw driver to pry the clock out of the dash. Start from the bottom. Also, if you ever wanted change your radio, the 3rd screw is right behind the clock to remove the center dash. (the other two are right under the center dash) After pulling out the clock, disconnect the wire harness fo both the clock and the hazards lights. After that look on the back of the unit and screw out the bulb. You should turn it half way and it should come out. Installation is the reverse.
Check out this link. It shows how to instal a radio on the 6gen Accords. It should help you
http://www.installdr.com/InstallDocs/Honda/PDF/466053.pdf
Good Luck
Good Luck
baki
03-11-2004, 10:13 PM
does anyone know where to buy the replacement bulb? I looked at radio shack, but they didn't have any. Any part #s or recommendations?
blacknight
03-12-2004, 08:08 AM
Go to the service department of any Honda dealer. It'll cost no more than $3
bensaccord
03-15-2004, 03:41 AM
For the longest time I thought that my bulb was out on my 99 sedan, then one night I pushed on the clock and the light came on. Now, whenever the light goes out I just push the clock back in a little and the light comes back on. Started after removing the dash for my new CD player and some other goodies. :grinno:
blacknight
03-15-2004, 08:37 AM
Your bulb is probably loose or something
