Location of signal light flasher units
Google
Web AF
GoinAllTheWay
01-21-2004, 08:52 PM
Ok...
Signal lights are dead. Not a fuse issue, Im almost certain its the flasher unit but I mite as well be looking for the holy grail because I cant find it. Ive found the flasher unit for the hazard lights, logic would dictate the signal light flasher unit would be in the same area but its not. Been to a Chev dealer and they brought up scematics showing it to be either behind the front left head light assembly (its not) or behind the left hand front speaker (its not there either). Does anyone own a 92 Cavalier Z24 and know the location of the signal light flasher unit? It looks like a large thymbal with two prongs. Any help would be greatly appreciated.
Thanks guys. :banghead:
heatherannie22
01-21-2004, 10:42 PM
What are your signal lights doing? You may just have a burned out bulb (you probably checked that already), or a short. I had a blazer that had a major short in the wiring harness that ran the tail lights and back turn signals, pain in the a$$!!!!
GoinAllTheWay
01-21-2004, 10:55 PM
What were they doing? Well to start with, they started flashing oddly, sometimes fast, sometimes slow then they stopped flashing entirely. You could still make them flash manualy by flicking the lever but now, the lites dont lite up at all. Hazard lites work fine so I dont think its a bulb.
heatherannie22
01-22-2004, 03:14 PM
I've seen that before, prolly your switch in the column, its about $15. Taking the column apart is a pain too. Thats the same thing my blazer did, and the first thing we replaced was the switch, but of course that didn't fix it because it was a wiring short. Hopefully yours isn't that. Did it start with one, or was it both of them from the beginning? I think my hazards went out, but my gas gage went screwy also, and my front turn signals worked, so yours prolly isn't wiring, but I'll bet its the switch.
GoinAllTheWay
01-22-2004, 05:00 PM
Yes, both sides started behaving oddly at the same time. Im certain it is the flasher unit and yes, taking apart the colum is going to be a pain. Need to get a special screwdriver but after that it should be smooth sailing. Just hope thats where it is, if not, buying a new car.
heatherannie22
01-22-2004, 05:58 PM
Ok, I don't think its a flasher unit, if it was, it prolly would have just quit altogether. I think its the switch itself, the one inside the column that the blinker lever is attached to. Ask autozone, they would know better that me, but in my case I couldn't find a flasher unit for the blinkers, only for the hazards. That was a blazer though, a little different, but if you're going to tear the column apart anyway, I would recommend replacing the switch while you're in there. I was wrong about the price though, its $41 if you dont have a/c, and $60 if you do, at autozone.
GoinAllTheWay
01-22-2004, 06:31 PM
The switch? Are you reffering to the actualy lever you use to activate the signal lights? Interesting though. Its possible but ive had signal lights go out on another car I owned at it displayed the same symptoms as the Z24. Odd flashing, sometimes fast, sometimes slower and then stopping all together. Thanks for the tips, when I finnaly figure it out, ill post the results here, hopefully it will help someone else.
heatherannie22
01-22-2004, 07:14 PM
Yes, the lever. But its not the WHOLE lever, you'll see when you take the column apart. Its hard to explain, I'll see if I can find a pic and I'll post it here. Try cleaning the contacts on the switch first, they may just be dirty, that happens a lot. But be careful, there is a bearing and a spring in the switch, and they have a tendency to fly out. A friend told me this who has more experience with these things. Try that before you go buy it, thats a lot of money to spend if it only needs to be cleaned.
heatherannie22
01-22-2004, 07:35 PM
I posted a pic. Its under general automotive images, and the name is turn signal switch.
GoinAllTheWay
01-22-2004, 08:49 PM
Hey thanx for that man, I appreciate your effort, I know what your stabbing at with that one. Nice 280 BTW, used to own one myself. Is that an RC you have in there as well?
heatherannie22
01-22-2004, 09:55 PM
Huh? Those aren't mine, thats a gallery for anyone who wants to post. I only posted the turn signal pic.
GoinAllTheWay
01-23-2004, 11:53 AM
OIC, my bad. Turns out the thing isnt in the steering colum either. I give up, going to take it to a mechanic.
GoinAllTheWay
01-26-2004, 02:34 PM
*bump*
Kmaxhhi
01-26-2004, 02:47 PM
Probably not the same location in a Cavalier, but a 96 S10 Pickup, it's under the dashnboard lower closeout panel, directly below the radio package.
Two silver canister relays...lone the 4way flasher, the other is the turn signals. BTW - my truck exhibited the exact same symptoms your car did....even down to the flashing rapidly then slowly. - After finally finding the relay and spending 3 bucks for the replacement, mine is fixed.
Best of luck - Kmaxhhi
GoinAllTheWay
01-29-2004, 08:49 PM
Sweet mother of God, I found it!! Similar location to above but no where near where the GM techs told me or the haynes manual. It mounted on a clip that was attached to the steering colum brace. If your heads on the floor and your feet over the headrest, it would be directly above and to the left of you. Funny thing is, the clip holds the flasher to the colum, you can pull it off and place it in plain site on the other side of the steering colum brace. Stupid location. I hope this helps someone out in the future. Thanks for all the help and input guys :)
ChevVan75
03-19-2004, 05:00 AM
I have the same problem with my 92 Cavalier. The blinkers slowed down for months, maybe 1/3 speed of normal. Once in awhile they would not work at all then next day work slow again. Now they are out permanent. Went to dealer and bought the flasher for the turn signals...$10.00 (it looks just like the emergency flasher only has 2 blue rings around it) but I couldn't find it anywhere. Took apart the whole steering wheel area and found nothing! I was ready to go to library and look in a service manual but decided to check online first.
I am glad I ran across this forum.
Hey, GoinAllTheWay .....if it's where ya say I owe ya a cold one!!
:iceslolan
rmc4th
11-07-2004, 04:06 PM
GoinAllTheWay thank you thank you thank you. Yo save me from going postal. I went so far as to put my legs over the headrest and my head under the steering wheel and I barely found it. Stupid Stupid Stupid location. Not to mention the Autozone part I had to replace it was larger so putting it in was a curse word or two.
GATW I owe you a cold one too
Thanks
rmc4th
tilla
01-01-2005, 07:16 PM
My '95 chevy PU just started flasher problems. The front left turning signal is flashing when the key is on, all the time ,fast.Clicka clicka clicka clicka! :screwy: Now I am trying to find the switch.
When I actually operate the turn signals , it operates normal, right and left.
I am ready to just pull the bulb! :sly:
tilla
01-01-2005, 07:48 PM
Found switch, replaced and all that changed is that it slowed to normal. Still , front left light only blinks without actuating the lever.
Google
Web AF
