98 s10 no fuel pump
Google
Web AF
TJTF150
01-21-2004, 05:25 PM
98 S10 fuel pump does not come on, changed fuel pump assembly but did not help, also switched the fuel pump relay out....not getting any voltage to the pump.....
Fox_Rocks
01-22-2004, 09:35 AM
if you jump the relay do you get power then? also, do you get power to the relay? if yes, then it could be a busted wire between it and the pump....if no then it could be your computer not sending a signal to your relay...when testing remember that when you turn the key on you only have power for about 3 or 4 seconds, so have someone key the ignition for you when your testing. Hope that helped.
Google
Web AF
