IMG Failure?
Google
Web AF
Mhoward74
01-21-2004, 11:29 AM
Can anyone point me at the Intake manifold Gasket. Based on some of the info posted here, I think that this is my problem. Engine shutdown at stops, idles really low, then cuts out. I need to drop it into neutral and rev to keep it going. Any help apprieciated. Thanks.
rodeo02
01-21-2004, 01:00 PM
Locate the large aluminum chamber on top of the engine (you may need to lift off the black plastic decorative cover off first). Follow down the left & right sides of the intake chamber, to where it mates up to the inside of each cylinder bank (left & right sides). You will see 3 runners mating up to each side, with a black plastic gasket material protruding out slightly between the intake & cylinder head surfaces. That's the IMG. It's a hard phenolic resin/plastic gasket that is prone to breakage. You can spray around with a fine water mist, or carburetor cleaner to pin-point where the leak is. G/luck
Joel
Dober89
01-21-2004, 03:31 PM
Im having the exact same problem with my Rodeo. I could hear a hissing noise from under the engine cover and now its in getting fixed. Also have to replace the o2 sensor and possibly a couple other things.
Google
Web AF
