93 Rodeo Fuel Pumpcheekatall 01-20-2004, 02:17 PM Car not starting. Should I hear the pump kick on briefly when the key is in the "on" position? I'm only see/hear the fuel pump work when I try cranking the (I have dropped the tank).... amigo-2k 01-20-2004, 03:13 PM Yup you should here the pump kick on for 3-5 seconds to pressurize the system with the key in the on position. cheekatall 01-20-2004, 04:28 PM I went as far as dropping the tank, only time the pump comes on is in the "run/cranking position". Since the car will not start, I can't verify if the pump continues to work or not. Funny part about the whole thing, is when I pull the relay off, I get the same results, is it possible the relay is faulty????? amigo-2k 01-20-2004, 04:32 PM Yup the relay could be bad. That is a cheap part to replace. cheekatall 01-20-2004, 06:12 PM I'll pick one up and give it a try, like you said it's a cheap place to start, thanks again let you know what the findings are........... + cheekatall 01-22-2004, 01:49 PM Since I had dropped the tank, I had decided I would replace Fuel pump anyways to keep from messing with the tank again. Once all was in place the car started right up. Guess the pump had a short or something (pressure related), what threw me off was being able to jump the pump and watch fuel come out the fuel line. I guess that doesn't prove it's defective, hence pressure test, thanks........ vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
