turbo with racing cams?/?96tegFOsho 01-18-2004, 11:50 PM I wanted to put turbo and racing cams on my 96 Integra RS but my brother told me they wouldnt work well together...is that right or that cant even be done? Information on this would be helpful. Thanks 96tegFOsho 01-18-2004, 11:55 PM And also, how much would racing cams set me back...there is not budget... knorwj 01-18-2004, 11:55 PM its a little more complicated than racing or non racing cams. i'm not an expert on the subject but there are a lot of different cams with different cam profiles out there, some i'm sure are more suited for N/A engines while others have profiles that are well suitee to turbo applications and will suit your needs quite well i'm sure. like i said i am not great with cam info so thats about all i can help you with. maybe someone with more experience on the subject can clear that up a bit. 96tegFOsho 01-19-2004, 12:01 AM thanks for the info...so now im sure it can be done...but do u kno where i can see cams and ther profiles... whtteg 01-19-2004, 12:01 AM You want to look for a cam with high lift and short duration for turbo motors and you want to look for a cam with high lift and long duration for N/A but not as high lift as a turbo cam. It can get rather complicated, but to tell you the reason why the "racing" cams will not work well with a turbo is b/c they will have too much duratiuon andthat will let some of the boost go right out the exhaust valves into the exhaust and you will have less air/fuel mixture in the cylinders. Make sense? 96tegFOsho 01-19-2004, 12:13 AM So if I added turbo and racing cams with high lift and short or long duration it would work out...but would it pass the smog test? whtteg 01-19-2004, 12:14 AM No, it will not pass smog. 96tegFOsho 01-19-2004, 12:19 AM aw...i guess i might have a change in plans... 96tegFOsho 01-19-2004, 12:28 AM but which of the two wouldnt let me pass smog, the cams or turbo vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
