Flashing 4WD light on dashboardhowardhouk 01-17-2004, 12:37 AM Just recently, when I shift from 2WD into 4WD, the 4WD light on the dashboard flashes all during the time I am in 4WD. Can anyone advise me on what this may be caused by? I searched and saw a message that some contacts may be dirty, but it didn't say which contacts. I also saw a message indicating a module may be going bad. Any advice would be welcomed. My e-mail addess is howardhouk@comcast.net. Thanks! 99TrackerConv 01-17-2004, 12:14 PM I'm asking around now and I'll tell you anything I hear. I personally thing that it's not keeping air presure in the differencial so the pump keeps coming on, making it flash an error warning. I'd get it checked out. 99TrackerConv 01-17-2004, 03:53 PM Well I got one reply for you when I asked... The contacts are in the Transfer Case and there is no module in a zuke, as it's a hand and the lever. that or a bad bulb in the cluster. 99TrackerConv 01-19-2004, 08:18 PM Here is anouther answer... The front dif may not be "locking in" if you have shift-on-flly. To find out drive in 4wd and get light to blink then jack the front of car up (one side will do). Then try to spin the tire by hand if you can the front dif is "not locking in" George 99TrackerConv 01-20-2004, 09:21 PM And another answer.... George is correct. The four wheel drive isn't locking in properly. There is a diaphram in the differential that is probably leaking vacuum. That vacuum is needed to engage the auto hubs. I had the same problem on my 00 Grand Vitara. I was lucky enough to have it happen during warranty, even though it was the last time I owned it bewcause after visiting the Dealer for problem 11 times in 8 months Suzuki bought it back from me and I bought an XL-7. Haven't had any problems since then. JumboCanada 07-15-2004, 03:45 PM Change the hose on the differential JumboCanada 07-15-2004, 03:48 PM Change the hose on the front drive housing right at the bottom will fix the flashingon 4x4 vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
