2000 S10 Tune Up PCV install
Google
Web AF
Dezmar
01-16-2004, 02:17 PM
Hey People, Does anyone have tips, or experiance doing a tune up job on a s10 4 banger 2200? It looks troubling, and how bout a PCV install--EZ or tough? Thanks for your help.
Dezmar
01-20-2004, 02:21 PM
I looked for two hours and cant find the pcv valve---HELP!
mjohn
01-20-2004, 03:11 PM
go to: Search this Forum, Top of this page on this Web Site... and put in: PCV + 4 cyl. (hit search)
SloppyShot
03-07-2004, 08:57 PM
I cant find the pcv valve also
ne1 know where it is?
1999 S-10 2.2
SloppyShot
03-31-2004, 07:55 PM
I still haven't found a pcv valve on my truck. Anyone know?
krueskrewer
04-29-2004, 12:32 PM
nope and good luck with plugs n wires
www451oa
04-30-2004, 10:09 PM
Most, PCV Valves are located on the valve cover. And are VERY easy to change. They slide right in and out. Try following your vaccume lines, one of them will lead to the pcv valve.
Terry1
07-21-2004, 07:39 AM
Apparently this forum is not designed for answering simple questions like, where is that PCV valve?
www451oa
07-22-2004, 12:19 AM
I've got a 94' 4.3L V6, My PCV valve is located on the Passenger side valve cover, dead center on the top of the valve cover. To change takes less than a minute.
But that's my truck, obivously a 00' 4 banger is a different engine, so I can't tell you for sure.
From what I've seen on other engines, it's always on/near the top of the engine.
chris2000s10
07-22-2004, 10:14 AM
it is right behind the "black box" that says 2200 that attaches to your TB. two clamps and one 10mm bolt hold it on... the pcv valve actuall connects its vacuum hose to the back side of this box
smokey041369
07-22-2004, 04:52 PM
on the 2.2 if you have the flat valve cover with a hose hooked into the rear pointing to the driver side and on to the front pointing to the passenger side the one in the front is your pcv valve
Terry1
07-23-2004, 07:08 AM
Thank you very much. I wasabout to give up and throw the valve away. Thanks for the quick response. This turned into a major mystery to the mechanics in my area. Terry1
smokey041369
07-23-2004, 03:42 PM
if a mechanic doesn't know where that pcv is maybe you should sell the info to them. glad i could help you
Google
Web AF
