92 Regal installing Prostart car starterGodd 01-15-2004, 01:09 PM Hi, I am installing a prostart ct-3300 car starter and have run into a snag. I require a schematic for the ignition cct. 92 regal, 3.8ltr Everything is hooked up according to prostarts instructions, car tries to start but,,, the fuel pump doesn't run so it just cranks for a few seconds then shuts off. There was a wire called the "5th relay output" which is not hooked up as their instructions did not specify where it goes. It is described for a)second ignition, b) accessories, or c)crank wire. If anyone has installed one of these or has a decent schematic ( the one in the Haynes book is garbage, it doesn't match anything) any information would be greatly appreciated. Thanks in advance vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
