Wiring Sub's with Amp to deck...alternator whine?...
Domer
01-13-2004, 04:25 PM
My friend and I are about to install his Amp, and 2-10" subs.
I was just checking on which side of the car should we run the wiring through? Because on my BMW E30 you can't run the wiring on the right side because that is the side the power in ran through. If you do...you will get alternator whine and hear your engine rev through the subs.
So on my buddies 1997 civic 4 door LX, does it matter what side I should run the wires through?
TIA
TIA
GScivic7
01-13-2004, 04:34 PM
just run the RCA cables down the opposite side that you guys run the power wire
PaulD
01-13-2004, 06:43 PM
Because on my BMW E30 you can't run the wiring on the right side because that is the side the power in ran through. If you do...you will get alternator whine and hear your engine rev through the subs.TIA
it keeps going ... and going .... and going
tibby01
01-13-2004, 10:41 PM
because it is the easiest way of preventing it.
