upgrade turbo time for my gtrdoc`` 01-13-2004, 08:51 AM hello everyone i have a almost standard 91 r32 gtr, im looking to do a single turbo upgrade for midrange power, i have come across an extremerylycheap HKS T04E turbo, i know they are perfect for a 1j or rb25 but will it be good for my rb26, i could also get another turbo ( HKS T300s) but its too big too dear and i really dont want to go down the strip too often. any advice would be tops thanks -kieran RazorGTR 01-13-2004, 11:04 AM first thing it would be easier if you told us what power you are looking for. doc`` 01-13-2004, 02:43 PM between 400 - 550 hp at the wheels RazorGTR 01-15-2004, 10:44 AM ok sweet. You don't need to go to the expense or deal with the lag associated with a big single setup. A pair of GT2530's which bolt straight up the factory manifold will flow that easily, so will Group A N1 Turbos. You are looking at a full bottom end overhaul to keep it reliable. The factory conrod bolts are not that strong and have a tendency to stretch and break off. There is quite a bit of associated gear needed to acheive your goal. doc`` 01-16-2004, 12:48 AM the hks t04e will cost me 550 bucks, the only reason why i would bother doing an upgrade, im happy with the standard power, but at that price i thought might aswell seeing is i can make my own manifold, and get a cheap wastegate. the t04e is a large turbo but do you think it will flow enough exhaust gases for the 2.6? R34 GTR 01-16-2004, 08:19 AM For that kind of power you will need other 'essential' bits like bigger injectors, afms, mappable ecu, decatt pipe & exhaust etc. I have used 2530's for two years with stock internals and not one thing went wrong except I did suffer a piston failure (my own fault). vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
