98 Camry headlightsGrizlo 01-12-2004, 07:04 PM OK I posted earlier about my blinkers going out. At one point about 6 months ago, the right blinker would blink double-time whenthe headlights were on. I was told to change the fuses and possibly the relay. I cahnged the fuse for the hazards because they were not working either and there was no fuse labled blinkers, only headlights (lh,rh) and hazards. As soon as I cahnged the hazard fuse, it blew when I turned them on. So maybe it's the relay? Ok then, which relay is it? The owner's manual does not clarrify and the box cover doesn't either. At least nothing that reads blinkers. Please help. Joe W 01-12-2004, 07:34 PM The fuse blowing for the hazards would usually indicate a short in the wiring.Do the turn signals work properly now?If not start looking backwards from the right blinker. yotatechie04 01-13-2004, 01:23 PM It's most likely a short, if you plug in a new fuse and it blows as soon as you turn them on, that's not a sign of a relay problem. As Joe said, you need to go and check your wiring--a very time consuming job, but it needs to be done. After you do this, find your short, fix it, then if the problem persists, you need to take it somewhere. kisswahili 01-13-2004, 06:18 PM just like grizzo said the owner's manual does not clarrify and the box cover doesn't either which one is the relay.... im trying to replace mine for my turn signals and hazards which went out a couple of days ago but i dont wanna pull out nuthin that im not to sure off.... is it a particular color ? or the exact location....is it one of the bigger lookin ones? yotatechie04 01-13-2004, 06:55 PM All right, clarification on all of this : The turn signal relay is not located under the hood with the rest of the relays and fusible links, it is located inside of the car, behind the lower kicker panel on the driver's side of the vehicle. It's located behind the fuse panel. kisswahili 01-13-2004, 08:09 PM ok so i need to remove my kick panel to get to it?>..... and how do i know which one the relay is.....sorry im a noob to this.... could u describe what it looks like yotatechie04 01-13-2004, 08:42 PM You will need to completely remove the kicker panel to access the relay. The relay is located behind the interior fuse panel, in a plastic holder, on the firewall. You should be able to see it as soon as you look behind the fuse panel. corvair 01-14-2004, 09:41 PM first thing to look for on those is the wire harness comming from the body to the trunk lid at the hindge area. fixed a lot of them there ewww_itz_bequang 02-02-2004, 10:11 PM check your side marker light, if one of your light burned out something it will do it. My friend has that problem on his accord, maybe it can help u out. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
