Keyless Remote Programmingstinger67L88 01-11-2004, 03:33 PM Can someone help me with the programming of my 2001 Corvette Keyless entry remote? I have two, #1 & #2 p/n 25695955 & 25695954. FCC: KOBLEAR1XT Thanks Stinger67L88 hi-octane@att.net :banghead: frankyrealtor 01-18-2007, 08:50 PM fob programming Onblsht 01-18-2007, 11:49 PM 1. Turn the ignition to ON. 2. Turn the radio to OFF. 3. Press the RESET button in order to clear any IPC warning messages. 4. Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank. 5. Press and hold the RESET button for 3 seconds. 6. Press the OPTIONS button until FOB TRAINING message is displayed. 7. Press the RESET button in order to begin the programming sequence. The message HOLD LK + UNLK 1 ST FOB will be displayed. 8. Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit. The receiver will cancel the programming sequence if any of the following conditions occur: • The program mode is exited through the DIe. • The ignition is turned to OFF. • The three transmitters have been programmed. • The RFA system has been in the program mode for longer that 2 minutes and not transmitters have been learned.... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
