removing gundam marker
Google
Web AF
David_
01-11-2004, 08:19 AM
hey, if i made a mistake with a gundam marker, how do i remove it? without removing too much or any of the paint?
also, is it safe to clear coat over gundams? and how long should i wait before doing the coat (let the marker dry...)
(i'm assuming i mark now, 2 days after the paint got on the shell)
01-11-2004, 09:37 AM
There's a Gundam Marker removal pen available; I got mine from HobbyLink Japan.
David_
01-12-2004, 06:32 AM
ok, thanks for the help...
now i know that lacquer is not meant to go over acrylic.... so can i clear over gundams? and can i clear over acrylic paints (without paint running, i don't mind if clear coat slips off the paint, i just don't want the paint to run....)
01-12-2004, 09:14 AM
I do Gundam panel lines last on a project if that helps you. I don't want to take the chance of finding out the hard way if they'll run.:)
David_
01-12-2004, 09:22 AM
oh damn......... ARGHHHHHH..... if they run im dead!!! can't do anything about it...... :( hoooooooo boy...... will a clearcoat look right if i mask over the panel lines? (only clear main area's)
01-12-2004, 09:24 AM
Depends on how good you mask the model; the more quality time you spend masking, the better the end result is likely to be. :)
Vric
Tamiya Thiner work without a problem
David_
01-12-2004, 09:29 AM
hmmmm..... but i realy don't want to remove the gundam......... i'll try it on a seperate peice of spare first.... thx for the help tho
Google
Web AF
