2000 chev express van keyless entryspeedgun 01-10-2004, 11:00 PM How can I reprogram this keyless entry without the dealer? I have a total of 3 remotes and I have only one working. It seems when the battery dies so does the remote...I have tried and errored by chance on some methods but is hopeless without the right combination. The Gun GMMerlin 01-11-2004, 08:14 AM Transmitter Synchronization Domestic Resynchronization may be necessary due to the security method that the remote keyless entry system uses. The transmitter does not send the same signal twice to the receiver. The receiver will not respond to a signal that has been sent previously. This prevents anyone from recording and playing back the signal from the transmitter. Resynchronization may be necessary under the following conditions: The transmitter battery is changed The vehicle battery is disconnected The transmitter buttons are pushed 256 times out of range of the receiver In order to resynchronize the transmitter with the receiver, stand close to the vehicle and simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds. The door locks should cycle in order to confirm resynchronization. speedgun 01-11-2004, 10:50 AM If resync doesnt work, how can i reproram the remotes without a tool? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
