Front Side marker/Turn Signal Lights
Google
Web AF
Shadow14
01-10-2004, 03:39 PM
Can any one help me figure out how to replace the front side marker/turn signal lights? I can't find any simply way and I know it is out there. Tried to see if it was in the "Mitchell" manual I purchased on eBay(don't buy one, it isn't worth the cost) with no luck or success.
ltdmont
02-18-2004, 04:25 PM
You have to go in under the wheel well. Remove the plastic screws of the mud guard lining. You can reach up there and twist turn the light assembly. It will drop down in your hand but will still be connected to the wiring. you can disconnect the wiring harness if you want but it is just another step. Don't go in from the front... it's a dead end.
G~
steve3b3
06-26-2005, 03:54 PM
G~
:cool: :cool: :cool: :cool:
Good information!
Last year we brought my wife's Montero sport into the shop for a marker light replacement, and it was a $60 repair. This time, the right side marker light went out, and I couldn't see spending that for a flippin' BULB! You've helped us alot with this bit of info.
Steve
ajbringle
10-22-2005, 07:59 AM
I got to mine (98) by using the screws behind the metal trim under light housing... snappes out by side of marker, slides out enough to get to screw that holds marker, then the one screw on top of marker next to headlight...
Google
Web AF
