TAKING OFF DOOR PANEL in 97 blazer
Google
Web AF
97blazerct
01-09-2004, 05:36 PM
i got new speakers for the front and back door speakers. i need to know how to remove the door panel to install them.. does anyone know?!?!? i know there is screw behind the door handel on the inside.. and 2 under the arm rest.. but i need to know exactly how to remove it and install it.. its 3 degrees outside right now.. and the wind chill is -20.. brrrrrrrrr SOMEBODY HELPPP!!!
oh and if you know how to install the thermostat let me know. i know approx. where it is but i cant find it because its under the throttle body cover..
divingduckman
01-09-2004, 05:46 PM
with power locks or with out? Here it is with power locks and windows. Pry out the control switch and disconnect the the connector. Then remove the door handle screw and the fastener.
Then pop out the cover (be careful i cracked mine doing it) Then pry off the cover in the door handle and remove the bolts.The door should pop free, rotate it up to get it out of the window jams and that should be it
97blazerct
01-09-2004, 05:51 PM
Then pop out the cover (be careful i cracked mine doing it) Then pry off the cover in the door handle and remove the bolts.The door should pop free, rotate it up to get it out of the window jams and that should be itI need to take out all the buttons to take off the control switch... ??? we cant get the cover out because the door handel is in the way...
How do we get the cover off with the handel there?
modification_inc
01-09-2004, 06:18 PM
Cant Help You With The Removal But Dont Pry To Hard Plastic And Cold Weather Dont Mix Well
97blazerct
01-09-2004, 06:21 PM
i know lol. But this guy said to take the the cover off where the door handle is. the door handel is too big the plastic wont come off.. maybe im misunderstanding him.. I have a paper on how to do it @ my house somewhere. it came with my head unit i got lastweek..
divingduckman
01-09-2004, 07:34 PM
No the handle and cover stay together. Just pop the cover out of the door panle and let it hang. And the control switch shold just pop out and u have to disconnect it. You have to weave the handle and cover through the hole in the panel.
97blazerct
01-09-2004, 10:58 PM
THANKYOU!!
97blazerct
01-10-2004, 10:36 PM
Well, today i was installing the speakers for my truck.. We got the back ones in but the POWER WINDOWS/MIRROR/LOCK buttons WOULD NOT UNPLUG!!! i dont know WHY!! i got the POWER MIRROR WIRE PLUG OUT BUT I LOST THE SPRING AND IT DOES NOT WORK.. WOULD THAT NOT WORKING MAKE IT SO MY INTERIOR LIGHTS WONT GO OFF? THEY WONT GO OFF, IT BUZZES WHENEVER THE KEYS ARE IN IT, AS THOUGH A DOOR IS OPEN.. WHEN ITS NOT. WHAT would be the REASON FOR the interior lights not shutting off.. and it thinking the DOOR IS OPEN?? Could it be the broken power mirror button??? I jus disconnected the fuse in the meantime.. heeellllpppp meeee!! any suggestions?
any suggestions for GETTING THE PLUGS OUT!!?
Google
Web AF
