96 s-10 dies while driving
Google
Web AF
bj126821
01-07-2004, 11:32 AM
I am at a loss, My 96 s-10 with 97,000 miles will die on me while I'm driving, sometimes I can put in netrual an restart it, then other times
it will just crank and not start. Sometimes I can drive it for 20 min, shut if off, come back in 5 or 10 min and it will just crank and not start. I can wait 5 min and it will start. I had a new fuel pump and filter installed in june of 02' and I just replaced the ign mod thinking that might be the problem but it still dies. I let the dealer have it for 2 days and the could find nothing wrong, no codes no nothing, I have it a a nother dealer now and they are getting the same thing - nothing. Does anyone know or have any idea what is going on?
NovaRod
02-16-2004, 12:06 PM
Have you had any luck finding the problem? we have a 96 2.2L with similar symptoms. We are trying to find a root cause of this problem as it seems to be a common problem in S10's.
Post your fix if you have one. We will do the same. Thanks!
NovaRod
http://www.automotiveforums.com/vbulletin/showthread.php?t=188705
oobie77777
02-27-2004, 05:33 PM
i just had the same problem.Mechanic replaced crankshaft sender and ignition switch.then found a loose ground wire on circuit 192.good luck.took them 4 days.
tj_156
02-28-2004, 02:07 AM
well....i had kinda the same problem. I bought a 94 s10 4x4 with the 4.3 vortec....and after a few weeks the rpms started to drop when i was slowing, like the idle control valve was clogged, which caused it to die a few times on me. I replaced that and it ran fine after that, but yours might be altogether different. does it just DIE, like with accelration? or when it hits low rpm's? if it does it intermittanly around low rpms, take your egr valve off and check it, clean it and or replace it. i've done both the idle and egr valves, and the truck runs fine now. your on the right track with the module, but check those valves if the truck just seems to idle down way too low and die.
wjwill6
02-29-2004, 12:31 PM
I have a 2000 S10 with the 2.2 engine. I have the same exact problem that you are discribing. It turned out to be clogged injectors, bad gas in the tank, and I need a new clutch safety switch. Now my truck runs like new again.
cobra1
03-02-2004, 05:39 AM
sounds like ignition switch to me.
ndsysv
03-02-2004, 11:48 AM
I have the same prob on my 98 2.2 its not the control modual or the coil packs. Ive also changed the fule filter. Ive been told it could be the oil pressure sending switch try that out and see what happens.
NovaRod
03-02-2004, 08:54 PM
I really think this has got to have a common source because of all the S10 owners having this problem.
I really appreciate the posts as we are starting to get to the bottom of it.
Possible fixes:
1- Oil Pressure Switch
2- Wiring on the fuel pump
3- Coil pack/ECM
4- Fuel Pump
5- Fuseable Links
6- Ignition Switch
7- Crank Trigger
8- Injectors
9- Fuel Filter (good call on this! Causes strange problems on an EFI engine)
10- Bad gas
11- Clutch safety switch
12- Low oil pressure
13- Fuel pressure
14- Possibly other electrical problems that deal with Relays/ignition, etc.
I'd like to see a schematic of the electrical wiring as it deals with ignition and fuel delivery.
s10georgia
09-14-2009, 08:25 AM
96 S10 2.2L Engine 5 speed.
When you think you have fixed the problem....bam it strikes again....
I have replaced all emission control sensors, the computer module, coil packs, egr, fuel pressure regulator, alternator, battery......what else is there? Can anyone give a POSITIVE answer to this problem instead of Bull? Thanks......Serious to to find the answer....reply!
manicmechanix
09-15-2009, 12:26 AM
My guess is it's something ignition related. When the engine cranks and no start, you need to find out what is missing, i.e., are you losing spark, injector pulse, etc? I would bet it is a bad ground or circuit running to the ICM. It's not easy to find an intermitent problem like this but if you start digging into the wiring harness the problem usually shows up.
johnrestine
09-25-2009, 05:45 PM
I found a good possiblility to everyones problems. the little black box under the ignition swith. I popped the cover off the bottom of it to expose the wires and wiggled them till i came to the pink wire. It has a loose connection! I plan on replacing it but i cant seem to find a socket small enough to fit the screws. so if anyone finds a socket to fit it, let me know the size! goodluck!
p.s. I jammed a penny between the soldered wire and the plastic and it seems to be holding up for now!
donscc
12-09-2009, 04:48 PM
what black box, my ignitiong is in the steering column and there is no black box under it????
MT-2500
12-09-2009, 05:34 PM
The post was refering to his black plastic ign switch.
donscc
12-09-2009, 05:37 PM
ign switch? where you put the key in?
MT-2500
12-09-2009, 05:39 PM
Welcome to AF.
This post was started over 5 years ago and has not even had any proper feed back.
Always check the date on a post and if it is old let the old and dead rest in peace.
MT-2500
12-09-2009, 06:14 PM
The ign switch is the electrical switching part.
The ign switch tumbler is where you put the key in.
donscc
12-09-2009, 07:34 PM
then where is the black box he was talking about?
MT-2500
12-10-2009, 10:17 AM
Read his post real good.
He was refering tho the electrical part of the ign switch.
This post is old and dead .
Lets hang it up and let it rest in peace.
Forum rules say if a post is old do not reply to it.
Google
Web AF
