Fujimi civic type-R
Google
Web AF
sneiser
01-05-2004, 10:00 PM
Hey i have been working on this new project and i have lowered the front end and looking to lower the rear... but unable to figure out how ... has anyone worked with this model? and does anyone have some suggestions on how to lower the rear?
Thanx in advance.
sneiser
01-06-2004, 08:47 AM
anyone at all????
joecwlaw
01-06-2004, 10:10 AM
anyone at all????
I think you have looked at my "HOW-TO" lower the S14. In fact, you can do something similar to my instruction.
1) chop the suspension, for Civic, 2mm is enough, and the rear should not be lowered more than 2mm.
2) you can use a styrene or metal rod to extend the lower part of the suspension in order to reach the suspension "arm" at the bottom. And then put a spacer between it.
3) for the rear part, you might need to shave the inner of the hub so that it could be mounted to the drive shaft.
4) to change the "camber" setting, simply drill the hole on the chassis towards the inner.
These written instruction can be read along with my HOW-TO pics. Hope this help.
http://files.automotiveforums.com/uploads/214573sus1.jpg
sneiser
01-06-2004, 05:52 PM
thanx alot .... ill try it. :)
Google
Web AF
